OSPF NM neighbor creation failed due to lack of memory. OSPF NM neighbor creation failed. The local OSPF router cannot exchange routing information with this neighbor. The local routing table may not be accurate, and there may be routing problems.
If the neighbor is configured through the MIB, try deactivating and reactivating the MIB. If the neighbor is discovered, the protocol will automatically try to create the neighbor again. If this does not resolve the problem, investigate the shortage of memory on this system. Make more memory available on this system.
Error
%p1% %p2% %p3% %p4% creation failed due to lack of system resource.
| Name | Type |
| p1 | String |
| p2 | String |
| p3 | String |
| p4 | String |
